civic vx Jdm Amber corners install
just figure out a way to mount them so they fit... its all plastic there so have fun with a sheetmetal screw
also its possible u might have 4dr corners, they are dif from 2/3dr
looks like u didnt slip it on slide holding part, lol hard to explain... corner light has the two pins on the outerside then it also has to slide into the other thing on the inside
fooo that thing never fits right, you can just adjust your headlight from the back of it.It will take that gap away i had the same problem no matter how you try to move it, it wont line up just adjust your headlight from behind it. You will see the screws just play with them and see which one position looks the best
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker »</TD></TR><TR><TD CLASS="quote">you dont have it in the track.. try again!</TD></TR></TABLE>
yea.. mine amber corners went on fine' you just messed up'
yes there on just fine know i just Fed up on the install there are clips on the side of the head light were you slide the coner light on to as a brace. thanks for all of the help guys.
Goodbye My Love
Jul 14, 2005 03:25 PM
