help cylinder 3 no spark
i just done a d16y8 swap and it wont start unless i give it gas , and when i release the pedal it dies on me , cylinder 3 isnt firing but its getting fuel , anyone know what may cause this ? bad ecu or is something wrong with my distributor ?
umm probably double check ur wiring..... Also make sure that the injector is working properly.... Check the plugs if they are still okay(if foul then change plugs) check wires.... But let me know how it turns out after all this....
