Engine swap? HF to SI
Old Dec 21, 2001 | 04:21 AM
Chuckles's Avatar
New User
Default Engine swap? HF to SI
I may be picking up a whole '90 SI engine/tranny swap for $200. Will it drop right into my '91 HF or will have to replace some stuff? Assume I get engine, tranny, & ecu. The SI engine has no distributor or engine harness. What about axels?
Old Dec 21, 2001 | 04:52 AM
markedOO1's Avatar
Default Re: Engine swap? HF to SI (Chuckles)
your gonna need new hubs to use the si axles....I did see someone on partstrader w/ hybrid axles for a si tranny and hf hubs... otherwise, it drops in...
Old Dec 21, 2001 | 05:51 AM
Chuckles's Avatar
New User
Default Re: Engine swap? HF to SI (marked001)
But if I do an EX/SI brake swap too then I'll be ok right?
Old Dec 21, 2001 | 06:03 AM
markedOO1's Avatar
right...
Old Dec 21, 2001 | 08:10 AM
Mugen Dom's Avatar
the ex brakes are bigger than teh si and ull need the axles from teh ex or si
Old Dec 21, 2001 | 08:40 AM
Chuckles's Avatar
New User
Default Re: Engine swap? HF to SI (jdmB18hatch)
will the hf axles work with the SI tranny?
Is this deal worth it? Figure it is pretty much a direct swap for 40 hp more.
Old Dec 21, 2001 | 09:13 AM
markedOO1's Avatar
definitely worth it...hf axles wont work w/ the si tranny... I'll try to find that ad on thepartstrader...
here it is... http://www.thepartstrader.com/single...1&adnum=235700
[Modified by marked001, 1:15 PM 12/21/2001]
Old Dec 21, 2001 | 09:17 AM
Chuckles's Avatar
New User
the car already needs the axles replaced so I'm not concerned about that.
HFpower
Jan 10, 2007 11:41 AM
pinecone
May 20, 2006 11:02 AM
JStone2775
Aug 20, 2002 11:16 AM
Nossy
10
May 4, 2002 10:00 AM
REDBARON
Feb 12, 2002 07:01 AM
