rubbing/grinding noise while turning right.
Like I stated above, my itr makes a rubbing/grinding noise. It only happens when cutting the wheel ALL the way to the right. I put the car in the air and tried to get a better look at the problem. I found that the car must have weight on the wheels to make the noise. I am having trouble deciding where the noise is exactly coming from. Sometimes it seems to come from the steering column and sometimes the front suspension. I checked and there is nothing actually rubbing against the stock wheel or tire.
Sorry if this is long or confussing---Thanks.
best thing to do is grab a Friend if you have any , and have him/her stand outside the car while u cut the wheel and drive. Do it slowly so they can figure out if its coming from the engine bay or wheel, i would also check power steering fluid as well
theguy22
22
Nov 6, 2011 10:58 AM
96f22b2
Oct 6, 2008 03:58 AM
