92 civic VX with a 95 JDM b15d swap
Old Oct 29, 2004 | 03:59 PM
felo's Avatar
Default 92 civic VX with a 95 JDM b15d swap
I recently put a JDM b15d engine on my 92 civic VX, Im not using the p07 ECU that came with the old engine instead I'm using a p28 ECU but I have encountered with the check engine ligth. my question to you guys is if the car wiring is the problem? since it is wire for the p07 and not the p28, also this new engine does not have an egr sensor plug so I have left the sensor out hanging. any idea on how I can resolve this problem?
thanks.
Old Oct 29, 2004 | 04:15 PM
esteps's Avatar
Default Re: 92 civic VX with a 95 JDM b15d swap (felo)
do you mean d15b?
Old Oct 29, 2004 | 04:29 PM
Jim Truett's Avatar
Default Re: 92 civic VX with a 95 JDM b15d swap (b16a93cx)
Trash the EGR. You don't need it anymore, and the P28 doesn't look for it anyway. Your CEL is most likely caused by the differences in the wiring of the VX o2 sensor. You will need the proper 4 wire o2 sensor, and you will need to convert the VX wiring to support it.
Old Oct 29, 2004 | 05:12 PM
DSRxCandyh2bEG's Avatar
Default Re: 92 civic VX with a 95 JDM b15d swap (Jim Truett)
that is probably what it is. O2 wiring is different on the vx and dx. 7 wire vss 4 wire. the p28 uses a 4 wire o2...
Old Oct 29, 2004 | 05:15 PM
Tad's Avatar
Tad
Default Re: 92 civic VX with a 95 JDM b15d swap (AVRh22EG)
jump theservice check connector so the CEL flashes telling you exactly what codes ur getting.
then go from there.
Old Oct 29, 2004 | 05:55 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: 92 civic VX with a 95 JDM b15d swap (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">jump theservice check connector so the CEL flashes telling you exactly what codes ur getting.
then go from there.</TD></TR></TABLE>do what this guy says first to see if its only throwing the o2 code or more but u will have to convert the o2 wiring over to 4 wire there are some helpful diagrams that show u how to do this on h-t. but on my car i just wired the new o2 to the ecu
Old Oct 29, 2004 | 08:24 PM
felo's Avatar
cool thanks I'll check for that, also whenever I plug the sensor to the idlecontrol module, the engine starts to rev up and down until it is hot. the Iddle control module is new. what could be causing this problem? and another thing the VTEC is not kicking in.
please help
thanks
wolfsbain
Feb 25, 2012 01:20 PM
tuned-civ
Jan 30, 2011 06:33 PM
hondaman92civic
May 14, 2010 03:09 PM
1988_96hb
May 23, 2007 08:30 PM
shivic
Aug 25, 2004 01:57 PM
