N.O.S. Install...
Ok. You drill holes into each intake runner about an inch from the block. Use the NOS hole tap to thread the four holes. Screw in the nozzles(Use teflon Paste on everything). Bend the 8 metal tubes(NOS has a tool for this as well, so you don't kink the lines) from the distributioin blocks on the solenoids to the nozzles that you just screwed into the intake. Come to SHO's Nitrous forum for some info on wiring the kit. Warning don't leave the nitrous forum though. It's getting to be a mix between clubsi and H-T.
what is the actual car color of your car? do you have any more pics...if you do can you send them to drew408@hotmail.com thanks!
vtecftw
Apr 15, 2007 05:45 PM
