need help will 92 gauge cluster w/tach into 95 dx auto with no tach.
Old Oct 29, 2004 | 11:26 AM
Spins's Avatar
Default need help will 92 gauge cluster w/tach into 95 dx auto with no tach.
Found a gauge cluster with tach at the salvage yard for cheap. Tried to install an found that the auto cluster has this big green plug. I assume it for the auto shift display. The cluster with tach does not have this but has a white plug which the auto cluster doesnt. So I wasnt able to plug the cluster up completely. the white plug has 5 pinouts wires colored blk/yell, red, blk, red/blk, pink/green. One set of wires coming from the green plug on the auto cluster is red, blk, red/blk green, yellow. Do you think I just need to hack and splice these wires together to make the cluster work? Without the white plug connected the only things working are temp gauge, high beams, turn signals, srs, battery light, dimmer lights, No tach or speedometer. Not sure about hatch light or oil pressure light.
Modified by Spins at 4:38 PM 10/29/2004
Old Oct 29, 2004 | 12:44 PM
Spins's Avatar
Default Re: need help will 92 gauge cluster w/tach into 95 dx auto with no tach. (Spins)
anyone? I thought I made a great find. which lead to me cracking the cluster trim . Which ended up with me breaking the trim trying to fix the a/c vent that was screwed up, do to me removing the trim without seeing the screw hidden underneath the haz. button.
Old Oct 29, 2004 | 02:41 PM
2fast4u831's Avatar
I'm really 2slow
All 92-95 clusters should work even jdm ones work fine without any wiring.
Old Oct 29, 2004 | 02:46 PM
chad's Avatar
Moderator
Default Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">All 92-95 clusters should work even jdm ones work fine without any wiring.</TD></TR></TABLE>
this is true
Old Oct 29, 2004 | 04:00 PM
Spins's Avatar
Well 3 plugs pop right in. the forth one is a large green one. Is has about 10 pinouts. there is no where for it to plug into. the hole on the tach gauge is only a 5 pinout .like i described above.
Old Oct 29, 2004 | 04:04 PM
Pete_SI's Avatar
Default Re: (Spins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spins &raquo;</TD></TR><TR><TD CLASS="quote">Well 3 plugs pop right in. the forth one is a large green one. Is has about 10 pinouts. there is no where for it to plug into. the hole on the tach gauge is only a 5 pinout .like i described above. </TD></TR></TABLE>
The same happened to me. their was one plug that didn't fit.
Old Oct 29, 2004 | 04:06 PM
Spins's Avatar
Default Re: (Pete_SI)
did your gauge cluster work without this plug?
I'm thinking I'll have to hack the green plugs wires.
I would like to find someone who has a car with working guages and do a swap to see if my gauges are functional.
Modified by Spins at 8:19 PM 10/29/2004
Stuominous
Apr 22, 2014 09:08 PM
GhostRidaz
Dec 24, 2010 07:52 PM
Niskyspy
Aug 30, 2007 03:37 PM
-16V-
14
Jan 3, 2003 10:41 AM
Hawd
Jul 24, 2002 11:52 AM
