CRX Suspension?
Yes. No matter what kind of suspension you have, adding bigger wheels will change the sprung weight of each corner and will change the suspension characteristics. A new motor is +/- depending on what you get as some are heavier than others and will change the weight distribution of your car.
when i put an Integra engine in my CRX the suspension that was beginning to get a little worn out quickly became VERY worn out. so yes, dropping a bigger engine into your car will definetely impact the way it brakes, turns, and handles.
eREXion91
Suspension & Brakes
Mar 8, 2005 09:56 AM
