Floor Jack points.....98 civic
Old Oct 29, 2004 | 09:55 AM
meaux's Avatar
Default Floor Jack points.....98 civic
Where can I see a pix of the floor jack points on a 98 Civic? Yes, I have jack stands.
Need to rotate tires.........
Old Oct 29, 2004 | 10:17 AM
EL Vap133's Avatar
Default Re: Floor Jack points.....98 civic (meaux)
Look under your car, you'll see them.
Old Oct 29, 2004 | 10:23 AM
marshun's Avatar
Default Re: Floor Jack points.....98 civic (EL Vap133)
the best advice i can give to anyone that is learning to work on cars, take initiative. you'll find that things come out pretty smooth if you just think about what youre doing and be aware.
Old Oct 29, 2004 | 10:26 AM
Jonas99's Avatar
Default Re: Floor Jack points.....98 civic (marshun)
you can use the front tow hooks, 2 jacking points under each sideskirt (front & rear) and rear tow hook.
Old Oct 29, 2004 | 10:38 AM
Prod's Avatar
Default Re: Floor Jack points.....98 civic (Jonas99)
if you're putting jackstands under the car the easiest way would be to jack it up from the front, look under the front bumper almost in the middle of the car theres a metal square sort of sticking down, theres your jack point. I haven't seen anyone post a pic. and for the rear someone already said the towhook so there you go hth
sshiny007
Oct 27, 2009 02:39 PM
TurboEM1
22
Mar 31, 2005 12:20 AM
Carlo
May 19, 2003 02:59 PM
Aeka GSR
Feb 28, 2003 06:27 AM
BigZ88
Jul 24, 2002 12:23 PM
