anyone put a different dash or front end on a 89 rex?
? i want a rex cause i think it would be a cheap project. i am thinking of an 89 si then put a b16a1 from sir in it$1300. then go turbo. so i want a different front end and dash. i found a 89, but the front is real bad, broken headlights cracked bumper, dented side fenders, and scratched up and dented hood. it's also primed cause the paint wore off i guess, so it is $700 and hsa 244k miles too.the dash is weather beaten too.thats why i ask, so anyone?
You could put in an Integra dash, think they look killer, if they're done right:
These are pics of it when i had it almost done:
This is a pic of it pretty much finished:
I can take more pics if you need em..
Thanx
Thanx
can anyone help out or not? i just need to know if i should bother w/ the dash cause i thinkit might be a bitch w/ wiring. is this a dumb question? it seems pretty straight ahead to me. dude why did you even respond to the post? are you dumb?
I did the install myself. Wasn't that bad just a lot of work. I got the dash from a friend for $350cnd which was complete ITR dash (cluster, armrest,harness,etc). To tell you the turth I found the wiring to be the easiest part of the install.
Need anything else, just ask..
Later
Later
JapJunkie
Nov 21, 2005 11:56 AM
