Short Shifter Installation?
Old Dec 20, 2001 | 06:22 PM
weezerdotc0m's Avatar
Default Short Shifter Installation?
Hello, I am new to this board and would like to know if anyone knows how to stall a short shifter into an Integra or perhaps knows a website with the information. Thank you in advance...
Old Dec 20, 2001 | 06:29 PM
IMPATIENT's Avatar
Default Re: Short Shifter Installation? (IdriveAgsr)
very simple, it's like 4bolts......what do you need to know?
Old Dec 20, 2001 | 06:33 PM
IMPATIENT's Avatar
Default Re: Short Shifter Installation? (IMPATIENT)
what year is your car and what kind of shifter did you get?......
Well,
I am going to install it tomorrow, but I just wanted to know if its easy or a pain to install. Also, do I need to know anything before I install it?...Its a 2001 GSR and a used dc short shifter... Thank you for the response...
[Modified by IdriveAgsr, 3:34 AM 12/21/2001]
Old Dec 20, 2001 | 06:40 PM
G_S_R's Avatar
I have the same shifter. install is kinda like a pain since I didnt take the exhaust pipe which is in the way. but its not that bad. I removed the shift linkage(?) too, to make it easier.
Ron
Old Dec 20, 2001 | 06:41 PM
IMPATIENT's Avatar
it took me ten minutes to install mne and the car was on jack stands, it's extremely simple, very common sense oriented, the only thing i would say is to make sure the bearing inside the shifter is good.....other than that it's a ******* snap. and make sure the bushings are covered with a good weather protectant, if there uncovered, mine don't have a cover and the shifter came with an all weather type grease that is corrosion protective.......
Old Dec 20, 2001 | 06:43 PM
Thank you guys...
Old Dec 20, 2001 | 07:53 PM
b18bvudoo's Avatar
New User
do yourself a favor and remove the b-pipe from the cat...a lot easier access. and your car is new so you dont have to deal w/ rusted bolts, etc.
also search overboost.com for a tutorial, its what i used.
Old Dec 20, 2001 | 10:25 PM
Default Re: Short Shifter Installation? (vudoo666)
Thanks vudoo66 for the heads up....
Old Dec 20, 2001 | 11:13 PM
LostGsr's Avatar
Heres a site that has instructions : http://www.overboost.com/story.asp?id=360
thesamesound
May 23, 2008 09:45 PM
idriveadelsol7
Dec 7, 2005 01:30 PM
s2k
Sep 11, 2002 12:24 AM
BrotherBrown
May 13, 2002 03:44 AM
