Car seems to turn over, but removed dist. cap and rotor won't turn while engine is cranking ?
Old Oct 28, 2004 | 08:26 PM
Dased530's Avatar
Default Car seems to turn over, but removed dist. cap and rotor won't turn while engine is cranking ?
about 4 days I ago I leave a clinic, start my car it turns on and dies, then I try to turn it on and it just turns over.
I hit the gas and it tried to start it again, it started for a second and then died again.
Now it just turns over, I took the dist. cap off and when the car is cranking the rotor turns maybe half an inch and falls back to the same position and it keeps doing this while cranking.
I thought it was my timing belt but I took off the valve cover and it seems to be intact.
I won't get to work on it untill maybe sunday so I'm just wondering what could be wrong
I hope it's the starter maybe ? or the dist. ?
Old Oct 29, 2004 | 04:19 AM
JimBlake's Avatar
Default Re: Car seems to turn over, but removed dist. cap and rotor won't turn while engine is cranking ? (D
Take out the sparkplugs so it's easier to turn. Take off the valve cover. Turn the crankshaft pulley counterclockwise & watch the camshafts & distributor. You'll have to look for what's broken. Maybe the drive lug where the distributor shaft engages the end of the camshaft?
Old Oct 29, 2004 | 05:43 AM
mildly.interesting's Avatar
broke cam
Old Oct 30, 2004 | 08:21 AM
Dased530's Avatar
well I had a friend take a look at it, the crank shaft turns over along with everything else except for the cams
he suggested snapped timing belt....
Old Oct 31, 2004 | 05:22 PM
chadwick16's Avatar
check bearing between distriduter and cams may be stuck. might need to replace
Old Nov 1, 2004 | 06:03 PM
Dased530's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadwick16 &raquo;</TD></TR><TR><TD CLASS="quote">check bearing between distriduter and cams may be stuck. might need to replace</TD></TR></TABLE>
will do, thanks for the help
Old Nov 2, 2004 | 04:29 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadwick16 &raquo;</TD></TR><TR><TD CLASS="quote">check bearing between distriduter and cams may be stuck. might need to replace</TD></TR></TABLE>If the entire camshaft (both of 'em?) doesn't turn, then it sounds like the timing belt. Check for bent valves.
vaderman_x
Jun 9, 2019 07:00 AM
millionhari
10
Jul 2, 2013 10:16 PM
infamy888
Oct 20, 2006 08:33 AM
asiansgoweeee
12
Jan 16, 2005 11:03 PM
ebelp
May 9, 2003 09:52 AM
