How do I remove the back seat?
Old Oct 28, 2004 | 07:50 PM
JonathanRuiz's Avatar
Default How do I remove the back seat?
Ok i have a 93 integra. Where exactally are the retaining bolds for the back seat. I cant seem to find them.
Old Oct 28, 2004 | 08:06 PM
penney's Avatar
Default Re: How do I remove the back seat? (JonathanRuiz)
look on the sides closest to the body panel and remove that little plastic ring
once its off, push sideways on the seat and it should come off...pretty simple
Old Oct 28, 2004 | 08:07 PM
CRX_1.8T's Avatar
if you search first, you will almost always find the information that you are looking for dude.
hopefully this helps...
https://honda-tech.com/zerothread?id=273469
Old Oct 28, 2004 | 10:31 PM
UNKNOWN_MEMBER's Avatar
Fold seats down, your face towards the back of the car, there will be 2 bolts on the left top of the left seat. Then move to the top right of that seat and there will be another two bolts now move the seat aside. Now go to the seat on the right, and on the top right remove the 2 bolts holding that seat down, now look at the side of the seat and you should see one bolt holding the seat sideways, take that off, now slide the seat to the right and take it off. To take off the bottom seats, there should be one bolt on the middle of the seat, you might need a extension to remove it but once you remove that bolt, pull the seats up so it'll be at a 90degree angle and then lift up. Once you try, it's pretty easy, just use common sense.
89sicivic
Mar 9, 2007 04:57 PM
jgrif08
Oct 23, 2006 06:08 PM
Powered By Garrett
Mar 26, 2005 08:29 PM
Griff
Apr 15, 2004 08:25 PM
Vinny Chase
May 22, 2003 10:48 AM
