went to replace the door and frame is bent, some help please?
well like the title says i was recently in a accident that messed up the door and fender.
so as i was going to replace them i took off the fender, then the door and noticed that the part of the frame where the door's hinges mount on is kind of bent in. So i tried sticking a pry bar through the electrical hole to pry it flat, no luck. I am kind of out of options and then it got dark.
I am wondering if it is possible to fix, and if it is how much do you think it should cost me at a body shop?
