fs: various honda parts....cleanig out the garage
most prices are best offer, im located just north of houston Tx and am willing to ship.
also am willing to set up an ebay auction for items as needed to reassure buyers.
d16z6 head w/vtec solenoid assmebly $100
d16z6 5 spd tranny mild 3rd gear grind at high rpm (syncromesh will help) $100
new in package d16 oil pump crank seal $5
92+ civic D series Competiton Clutches Strip pressure plate, installed and used for less than 2 miles $150
d16z6 flywheel $25
d16 crank needs to be turned $15
D series 5 spd starter $25
Buddy CLub style rear bumper 92-95 2/3 dr civic fiberglass $25
d16y8 intake manifold with rail and throttle body (no map/ tps) $75
92-95 civic ex throttle body w/map sensor $30
92-95 civic sedan driver side mirror $35
obd2 civic ex distributor $90
92-95 240cc injectors $60
D series sheet metal oil pans (quantity 2) $15 each
96+ civic alternator $45
92-95 civic driver side motor mount steel NOT aluminum $10
92+ prelude egr valve $30
97-01 JDM h22s oem Header $100
92-96 h22a prelude throttle body ( no TPS) $40
92-96 h22a jdm intake manifold $80
92-96 h22a bare block $250
92-95 jdm prelude engien harness UNCUT $100
92-95 jdm h22a fuel rail $20
92-95 prelude underdash and udnerhood fuse boxes $25 each
sr20de 1992 high port cams (intake and exhaust) good for 10+ hp on 95-00 sr20de's $100
sr20de valve cover $60
90-93 accord egr valve $30
L1H1 NTK o2 sensor(wideband) low miles $50
90-93 accord PS pump $30
VSS (2) $20 each
d16z6 flywheel $25
VSS (2) $20 each
Simple
Jul 19, 2005 06:23 PM
