stock height
wait...so the front is suppose to be higher? well my calculations are off, can some one measure like the bottom of the center cap to the fender? cause i dont think i can eyeball the exact center of the cap
. i need something more consistent to hook the measuring tape to. thanks
i'm just seeing if the owner before me lowered my car. it does look kinda low. but the type r did come a little lower than the gsr. i'm just checking before i do anything myself to it.
I measured the distance from the ground (flat garage floor) to the lower edge of the jacking points (the metal strips which extend down underneath the rocker panel). I used a measuring tape, and the width of the body of the tape measure is specified on the side, so I added that to the measurement of the tape that extended. I think you can get a more accurate measurement of ride height this way.
Distance was 5 7/8" for the front jacking point behind the front wheel, and 6 1/4" for the rear jacking point in front of the rear wheel. These are accurate to the nearest 1/32"; they just happened to fall at these even intervals.
My '01 R is all stock, except for the tires that are on it right now, which are Michelin Arctic Alpins in the stock 195/55-15 size. They have good tread in front, somewhat worn in the rear, with maybe 1/8" more tread in the front than the rear. (I just put them on - they don't necessarily wear that way.)
HTH
[Modified by nsxtcjr, 5:59 AM 12/21/2001]
HTH
i checked my springs but i cant find any logo or company name on it. but the struts don't look like stock because i see one marker writing on it. i cant read it but there is some writing on it.
well can someone try to measure from the bottom of the center to the fender for me?
thanks
forget that, any stock R's in orange county or orange wana meet up for a little bit so i can compare the height?
we can have a little meet.
[Modified by type R 599, 12:06 AM 12/22/2001]
thanks
well the tire presure could affect the height slightly.
thats why i wanted to measure the rim to the fender. thanks
[Modified by nsxtcjr, 7:07 PM 12/21/2001]
hm..so i guess my car is lowered then. cuz i got 13.5 inch front and rear. both are exactly the same. now the thing is..i dont know what suspension did the guy have before i got it. oh well, thanks for the help nsxtcjr!
mikeycivic
Jun 26, 2008 01:06 PM
