ecu question.........?
i found a pg7 ecu and tried it in my car. right off it trew 2 codes. code9 and code 19
code 9 is a cyp sensor.
code 19 Automatic transmission lockup control valve
i ask another guy and he said that it is from 86-87 integra automatic car. he called it pre-obd0
do they make 2 pg7 ecu's?
will the code 19 cause the ecu to run in limp or safe mode?
i am going to the salvage yard tomorrow...1hr. drive away. what ecu will work for a 91 crxsi....can i use the pg7 from the 88-89 integra..or the pr4 from the 90-91 integra? or do i have to use a pm6 only?
