code 22, can i ground the wire that goes to the vtec oil pressure sensor?
Old Oct 28, 2004 | 03:31 PM
Sinner's Avatar
Default code 22, can i ground the wire that goes to the vtec oil pressure sensor?
I want to test if the problem is the wire going to the oil pressure sensor. I figure if the vtec oil pressure sensor gives a ground with the key is in the 'on' position that I can tell if the problem is the wire.
Does that sound correct?
Nick
Old Oct 29, 2004 | 04:39 AM
JimBlake's Avatar
Default Re: code 22, can i ground the wire that goes to the vtec oil pressure sensor? (Sinner)
That pressure switch is closed when the pressure is low. One of it's wires goes to ground, I think at the thermostat housing. Check continuity of that wire to ground. Check continuity across the 2 pins of the switch when the engine's turned off.
The ECU wants to see that circuit go open when it has enough oil pressure.
Old Oct 29, 2004 | 07:16 AM
Sinner's Avatar
thank you for the reply, its very helpful!
Nick
JimRaynor90
Mar 2, 2015 05:41 PM
obuhmyuh
Feb 24, 2008 08:20 PM
Red_ED8
Nov 19, 2007 06:26 AM
jdmbreed
Sep 26, 2005 07:56 AM
LAKER HATER
May 16, 2004 11:52 AM
