problems with 93 accord
hey i have some problems with my daily driver it will just out of no where die then if i leave it there over night come back in the morn it runs like nothing ever happened, happened twice to me now. any ideas?
Do a search for "main fuel relay". You'll find lots of info on your likely problem.
When it dies you need to determine whether it's a fuel or ignition problem. Pull a spark plug wire and install an old plug and check for a good spark to the plug w/ the plug body grounded against the engine. If you have fire, it's likely the main fuel relay is defective. This is a very common problem on Accords from the early 90's.
good luck
good luck
econobox
Oct 21, 2004 05:25 PM
