CAR died...HELP ME!!
Old Oct 28, 2004 | 01:43 PM
bcphatchback's Avatar
Default CAR died...HELP ME!!
Car's been running fine, I've been hearing a buzzing noise near the timming belt. Never found out the cause but it didn't cause me any problems. Last night the buzzing got loulder, and as a drove off a few feet later the car just shut off on me. It wont start anymore!!
Here's a list of info;
Timming belt good
alternator belt good
1/2 tank of gas
battery nice and charged
engine cranks fine but wont start
sparks plugs good
fuel pump primes fine
disturbutor cap and rotor still good
what can be the cause of my car not starting?!?!
Old Oct 28, 2004 | 02:13 PM
hatchback_al's Avatar
Default Re: CAR died...HELP ME!! (bcphatchback)
All I can tell you is check for spark on each plug by removing the spark plug for each cylinder, insert it in the end of its corresponding spark plug boot, ground it to something, and crank the car over. If you have spark at all 4 plugs and you know you have compression in the cylinders then it has to be a fuel problem.
Old Oct 28, 2004 | 04:54 PM
Default Re: CAR died...HELP ME!! (hatchback_al)
all sparks plugs are good car was running fine before it died.
removed fuel rail and pluged the injectors on the rail but not on the intake manifold, all injectors sprayed fuel through while cranking the engine...
IM STUCK!!!
Old Oct 28, 2004 | 04:58 PM
Grand141's Avatar
Try cheaking the alternator it tends to create a buzzin sound with it wants to die
92accordjohn
Mar 20, 2008 05:45 PM
SimplyTron
Feb 19, 2007 12:08 PM
Turbo D17
13
Jun 3, 2004 08:00 PM
I3ackfire
22
May 14, 2004 09:50 AM
StimpyBoy
Nov 16, 2003 09:35 PM
