mini-me compression numbers!!!!
Old Dec 20, 2001 | 02:38 PM
sicivic's Avatar
Default mini-me compression numbers!!!!
Today I compression tested my 89 Civic Si with mini-me swap. It checked as follows:
#1: 220 psi
#2: 220 psi
#3: 210 psi
#4: 210 psi
This is quite surprising. The manual says for the stock motor which is 9.1:1 that the compression should be 160 psi. The mini-me swap upped the compression a good bit. Does anyone know how to convert psi readings to compression ratio?
Old Dec 20, 2001 | 02:41 PM
rainforest's Avatar
Default Re: mini-me compression numbers!!!! (sicivic)
what head are you using the z6=10.4 comp and the y8=11.1comp those are not 100% accurate but close enough to within like .2.
Old Dec 20, 2001 | 02:44 PM
sicivic's Avatar
Default Re: mini-me compression numbers!!!! (rainforest)
I'm using the Z6 head. How did you find the 10.4:1 ratio for the Z6 head?
Old Dec 21, 2001 | 09:10 AM
rainforest's Avatar
http://www.prestage.com/carmath/calc_compression.asp
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
Firstoost
Apr 26, 2006 05:30 PM
DeadVet
Mar 30, 2005 04:37 PM
DeadVet
Feb 9, 2005 12:34 PM
K20 EG
Jun 17, 2003 11:26 AM
