Clutch going bad?
I just notice recently when Im driving in the low rpm's when I hits the gas for WOT it slips, but when im in the middle/high rpms I floor it , it doesnt slip at all, its a stg4 clutch master... is my clutch going bad? but if i ease on the gas without flooring it through the lower rpm's it doesnt slip, only when i give it gas in the lower rpms if im in 3rd/4th/5th/ and I floor it thats when it slips
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">I just notice recently when Im driving in the low rpm's when I hits the gas for WOT it slips, but when im in the middle/high rpms I floor it , it doesnt slip at all, its a stg4 clutch master... is my clutch going bad? but if i ease on the gas without flooring it through the lower rpm's it doesnt slip, only when i give it gas in the lower rpms if im in 3rd/4th/5th/ and I floor it thats when it slips</TD></TR></TABLE>
yes... give it some time and it will start slipping in higher rpms
Here's how you test:
Drive a little in 1st gear (to like 10mph)
Shift it to 4th gear...if it stalls, the clutch is good. If it revs up, your clutch is bad.
Its okay, oem exedy replacement clutches on ebay are only like $130...clutch discs are only $50 if you only feel like replacing the disk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">it shouldn't be slipping then unless it's worn out...how long has it been in the car? mileage?</TD></TR></TABLE>
Im not sure, I want to say 50-60k
thanks dustin, ill give it a try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote"> not sure, I want to say 50-60k
Yep I'd say that clutch is done and will continue to get worse and slip more. Time to change it out for a new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Here's how you test:
Its okay, oem exedy replacement clutches on ebay are only like $130...clutch discs are only $50 if you only feel like replacing the disk.</TD></TR></TABLE>
it rev'd up
it rev'd up
it rev'd up
Your clutch be dead then!
it rev'd up
</TD></TR></TABLE>Your clutch be dead then!
