Another Rear subframe question. EK and ITR
Ok I searched and saw that EGs swap just fine with DC Integs. The JDM ITR uses a 23mm rear sway. Am I correct in assuming the rear sub frame is somewaht reinforced for this? Cause US ITR only has 22mm. Can I take say a ITR rear subframe and lca and put it on my EK? I have a GSR sway bar but the brackets and endlinks dont work. Plus I have had previous damage to my subframe.
Or should I try that huge reinforcement plate trick and get SI brackets and endlinks? thanks guys for the help.
i dont think it would be worth the trouble as the subframe wouldnt fit the rest of the car and the amount you would spend wouldnt be worth it.. i would just get the ASR kit or go with the Comptech setup as im doing.. if you wanna save some money, call Comptech and they will sell you the tie bar only for $219.. i bought one today actually.
tinkfist
25
Nov 5, 2002 10:11 PM
