side marker wiring
yeah i searched and everything and i did all the wires correctly but i ended up blowing some fuses. i check every single one but i can't get my tail lights to work. they work when i press the brakes but not when i turn them on at night. The corners dont work either except when i use the turn signal; and also my gauge lights are out but for some reason when i press my alarm the dash lights upstill weird. I need help what can i do??? I have a 95 cvic hatchback cx
exactly how did you wire your side marker lights to affect the interior n rear lights ? all you needed to do was tap off of your signal or parking lights in the front of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punku10 »</TD></TR><TR><TD CLASS="quote">how did you wire them up?
whatever you did.. reverse it
there are three wires going into your turn signal.
you want green and black.. tap into them and you should be set </TD></TR></TABLE>
Im about to put in my Stanley eg Sidemarkers, for them to just turn on when I signal, i just tap into green and black, or are those the wires so that they stay on constanly and just blink opposite of your front signal?
green and black will turn your side markers into turn signals that will blink exactly when your front turn signals blink.
if you want them to be on everytime you turn your lights on just tap into the black and other wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Everyone blows the fuse. Just up it to a 15amp.
i never blew it
i never blew it
janz3n
May 22, 2012 04:40 PM
EFLX
Jun 13, 2010 08:21 PM
