Motor won't start
Old Oct 28, 2004 | 02:45 AM
t3hatch's Avatar
Default Motor won't start
Hi
I bought a built b20 (sleeved,8to1 comp.)off ebay, put it in my car and I can't get it to start. A compression test showed psi of 63, 61, 13, 61. So, I pulled off the head, and the head is fine. The head gasket looks to be bad. It is a triple layered steel one, and it looks as if its blown on all cylinders. Does anyone think this head gasket could be the single problem of the low compression. Any help appreciated. Thanks
Old Oct 28, 2004 | 08:46 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Motor won't start (t3hatch)
damn, that is hella low of a compression! get another head gasket to raise up a little
Old Oct 28, 2004 | 08:59 AM
TwoRedEGgs's Avatar
Putting a new headgasket will not solve this problem. Those number are EXTREMLY low. How did u do the compression check, how long did u let it crank.
Old Oct 28, 2004 | 11:36 AM
t3hatch's Avatar
Default Re: Motor won't start (TwoRedEGgs)
I tried compression tests a couple different ways, taking out a spark plug and cranking it, then I took off the timing belt and closed both valves and cranked it by hand. Both ways gave similar numbers. What should be the next thing I should look into besides head gasket. Also, the compression is about 8.7 to 1, I mistyped it earlier. Thanks guys.
Old Nov 8, 2004 | 09:49 AM
Cyphear's Avatar
I think its just a bad headgasket.
hari2m
Honda Civic (2001 - 2005)
Dec 11, 2018 04:55 AM
dskater4111
Aug 13, 2008 05:17 AM
blackhatchb20
Dec 1, 2004 05:45 PM
turbo_ef9
Apr 13, 2002 11:36 AM
