Gauges
Old Oct 28, 2004 | 01:15 AM
wing's Avatar
Default Gauges
Hello!
I am interesting in buying some gauges and I cant decide which one to buy. I have some question about the Blitz DC 2 series. OK I must buy a live unit that i can plug in my gauge. The live unit can control up to 3 gauges, that mean that i buy these three gauges (oil/water temp., oil/fuel press. and boost) and one gauge can read two diferent readings. Example. If I have oil/fuel press. gauge that gauge can read oil and fuel pressure, but only one reading at the same time? example if I want to read an oil press. i must switch to oil pressure? If I buy these gauge i get two sensores? Or i must buy two live unit and two oil/fuel press. gauge? Can I plug instead an boost gage an EGT gauge? Can someone explain it to me how this thing work and what I must buy that i can read a oil/fuel press., oil/water temp. and EGT?
Thanks!
Thanks!
Old Oct 28, 2004 | 06:05 AM
2jz-gteTT's Avatar
Default Re: Gauges (wing)
Get Defi's
Old Oct 28, 2004 | 06:20 AM
PrettyLude's Avatar
the blitz gauges are very pricey
Old Oct 28, 2004 | 07:38 AM
IN VTEC's Avatar
I think the one gauge, two readings only applies to the temperature sensor. Otherwise, you need to buy a separate gauge for each parameter you want to monitor.
The Suprastore has some good pricing on the Blitz stuff and lower than comparable Defi stuff.
Old Oct 28, 2004 | 09:47 AM
wing's Avatar
Default Re: Gauges (IN VTEC)
I think i ll get a defi link series gauge.... thanks for your answear!
by by
pcguy760
Jul 2, 2006 10:17 AM
Jon Nelson
Apr 17, 2006 05:22 AM
RACEPAK
Oct 29, 2005 04:26 PM
iH8RICERZ
Nov 25, 2002 03:02 PM
