VAFC on a k20a3?
How well would a v-afc controller work with a k20a3(civic si), since the vtec in it...kind of ...isnt vtec. Does anyone have vafc on their k20a3?
Also...are there any upgraded cams available for the k20a3. And no...im not gonna do a head swap.
Basically what i wanna know...what basic upgrades will make a k20a3 better? I read about a ep doing high 14s with i/h/e....thats a pretty good gain over stock.
Modified by TPreludeSi at 11:16 PM 10/27/2004
The VAFC II is not useless. You won't see amazing gains but you can tune your air/fuel. If you plan on swapping the motor you'll have it for when you get real vtec.
doesn't look useless to me:
http://www.tprmag.com/issue/7/7_apexi_civic.shtml
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">VAFC will not work.
sorry but you are 100% incorrect
it WILL work fine</TD></TR></TABLE>
quite right
quite right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystar »</TD></TR><TR><TD CLASS="quote">quite right. VAFC is not useless. but it's not optimal solution either. it properly allows you to tune A/F but lacks other capabilties. </TD></TR></TABLE>
quite right also
quite right also
V-AFC is useless. It's a waste of extra money, go with a AFC why do you need to lower the VTEC engagement point when it doesn't exist. If you have a intake, race header and exhaust you may want a AFC to tune the A/F ratio because a RH will lean the motor out too much.
what other capabilities do you want for about $250?
turbo or nothing!
