b16a1 throttle body's
what car am i looking for when i am looking for a bigger throttle body....90-93 integ or can i use somthing else? can i use a itr one? my map is on the fire wall i cant use one where the map is in the throttle body or can i? need help i am a dumb *** when it comes to stud crap like this
GSR or b16a2 60mm throttle body..
they can be bored out to 64mm if needed..
ITR throttle bodies are very overpriced but can be bored out to 65mm and tapered out to 70mm
Or just bore out your stock b16 throttle body to 62mm (ITR spec)..
...Or just bore out your stock b16 throttle body to 62mm (ITR spec)..
Jhill on here bores throttle bodies and does the best job I have seen.
http://www.proflowdesign.com/
check it out...
check it out...
92integraVTECgsr
Oct 6, 2007 10:21 AM
