Converting to electric windows
Old Oct 27, 2004 | 08:22 PM
dornon13's Avatar
Default Converting to electric windows
Hey guys how hard would it be to convert from standard windows to electric....what other ways are there than buying a kit such as autoloc
Old Oct 27, 2004 | 09:03 PM
Proper's Avatar
Default Re: Converting to electric windows (dornon13)
This past weekend I put power windows in my ef hatch. I used power window motors and racks from an EF 4dr. The holes for the motors were already there so it all just bolted in. Works great and I couldn't be happier. You should see if a power window setup from the same gen car you have will work. It's worth a shot
Old Oct 27, 2004 | 09:17 PM
dornon13's Avatar
Default Re: Converting to electric windows (Proper)
thanks dude i thought it should be easy but wasnt sure
Old Oct 27, 2004 | 10:38 PM
hunghimself's Avatar
what about the plug? is it already there too?
Old Oct 28, 2004 | 04:00 AM
dornon13's Avatar
Default Re: (theguppies)
id say you need diff door panels to or you could cut a hole i guess
Old Oct 28, 2004 | 11:08 AM
Proper's Avatar
No the wring(I assume that is what you meant by plug) wasn't in my car so I had to completely wire in the windows. Not too much trouble though. and if there is a car the same model as yours w/power windows you can get their door panels too and not worry abou tthe hole where the crank used to be. Since NO EF hatches in the U.S. came with power windows I am going to have the bottom half of my door panel re-upholstered and have the hole covered up.
Old Oct 28, 2004 | 01:19 PM
dornon13's Avatar
Default Re: (Proper)
i actually am looking into buying an EK so it wont be a problem..i want to convert it to leather to so door panels will be needed anyways.
efjones9
Jul 1, 2010 11:07 AM
4g4dcruisin
Jun 17, 2009 02:48 PM
skidmarkroyalty
13
Mar 24, 2009 02:00 PM
thenick
16
Jun 9, 2004 10:28 AM
whagkangmakulet
Sep 13, 2001 05:37 PM
