t25 on a d15 del sol
Old Oct 27, 2004 | 07:30 PM
94ta_lt1's Avatar
Default t25 on a d15 del sol
i'm running a t25 at about 6 psi on a d15 del sol. i'm going to run it through a 2G eclipse stock intercooler. What size intercooler piping should i use. Also, what size downpipe do i need to make. also do i need to run different plugs or gap the plugs different?do i need to turn the dist. any to retard the timing? thanks
Old Oct 28, 2004 | 06:50 AM
93turbo16's Avatar
so you are already running? and you don't have fuel management? (injectors,FMU,fuel pump) type stuff? You are just going to run 6 pounds untill it blows up? You need to read up just a bit more. to answer you questions
1) 2.25
2) 2.5
3) NGKs or something colder
4) some come pre gapped, but (.028-.030) gap
5) retard the timing
Old Oct 28, 2004 | 10:02 AM
94ta_lt1's Avatar
Default Re: (93turbo16)
no i am currently putting it on. i have larger injectors and a safc. i just wanted to know what plug number to run and how much to retard the timing
Old Oct 28, 2004 | 10:17 AM
nonvtecD's Avatar
http://www.ecimulti.org/uberdata Get this first
ChRiS_p123
Jul 16, 2010 04:48 PM
barhonda_delsol
11
Apr 11, 2007 06:10 PM
93c1sol
Jan 7, 2006 09:43 AM
jaydmej1
Feb 18, 2004 07:47 PM
BoostedD15B7
Oct 17, 2003 03:18 AM
