New manifold (56k no way)
Old Oct 27, 2004 | 06:50 PM
wantboost's Avatar
Who is Mr Robot?
Default New manifold (56k ok)
This is my new manifold, it was made by bailhatch. b-series, (he also has them for you sohc guys too) mig'd mild steel. 35/38mm wg flange, t3flange. he also ceramic coated it for me too.
sorry forthe size, my pc is queer at times
some construction pics
The end result
[IMG][http://www.we-todd-did-racing.com/we...DE%3D.jpg/IMG]
Modified by wantboost at 9:40 PM 10/27/2004
Modified by wantboost at 9:41 PM 10/27/2004
Old Oct 27, 2004 | 07:02 PM
The Destroyer's Avatar
Default Re: New manifold (wantboost)
The welds look pretty damn good, how much did you pick it up for?
Old Oct 27, 2004 | 07:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: New manifold (Vtaaak y0)
yea, the welds are damn good. you'll have to pm him for pricing as each setup varies.
Modified by wantboost at 8:25 PM 10/27/2004
Old Oct 28, 2004 | 06:10 PM
oxSLEEPERxo's Avatar
what kind paint did you use to paint the manifold?
Old Oct 28, 2004 | 06:20 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: New manifold (oxSLEEPERxo)
it's not paint. it's ceramic coated
Old Oct 28, 2004 | 06:37 PM
Terrabomb's Avatar
So my aunt owns a ceramic shop. Is it possible to get your hands on the liquid jet hot coating? She has the kilns to make the peices with the coating on them.
Old Oct 28, 2004 | 06:48 PM
Bailhatch's Avatar
Default Re: New manifold (Terrabomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Terrabomb &raquo;</TD></TR><TR><TD CLASS="quote">So my aunt owns a ceramic shop. Is it possible to get your hands on the liquid jet hot coating? She has the kilns to make the peices with the coating on them.</TD></TR></TABLE>
Thats what this is. Its a ceramic coating in liquid form that I spray on with a detail gun. It gets baked to release the solvents and you're left with a coating that can handle 1500-2000* EGTs. It has very good insulating properties which should easily offset the heat sink nature of thick walled manifolds like I build. Lower underhood temps and more heat energy directed into the turbine are a couple of the main attractions for me. It happens to be VERY abrasion/chip resistant too.
your aunts kiln would work great for this. I use a glass blowing kiln (same as pottery/ceramics basicly but with some fancy digital temp ramping controls) for the higher cure temps and a convection oven for the lower ones.
Old Oct 28, 2004 | 07:36 PM
Default Re: New manifold (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
your aunts kiln would work great for this. I use a glass blowing kiln (same as pottery/ceramics basicly but with some fancy digital temp ramping controls) for the higher cure temps and a convection oven for the lower ones.</TD></TR></TABLE>
I have a kiln at my school, its a cermics glass, she doesnt have a sprayer though.
Old Oct 28, 2004 | 07:37 PM
wantboost's Avatar
Who is Mr Robot?
same here, im gonna ask my teacher if i can use her kiln, lol
Old Oct 28, 2004 | 07:49 PM
Bailhatch's Avatar
Spraying it is the easy part if you can paint. Just need a big tip because of the large solids in the coating. The prep work is the most critical part. It must be sandblasted in a rather particular manner, cleaned and sprayed asap to ensure good adhesion. Some of the really dope coatings are only available to wholesale custys also due to the toxicity
enrike
Welding / Fabrication
11
Sep 8, 2009 04:38 PM
LostCRX
84
Feb 27, 2005 12:55 PM
kevino002
Jan 5, 2005 08:48 PM
hotrex
15
Dec 13, 2004 09:41 PM
Greyout
Jun 28, 2003 10:30 AM
