Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Eibach Suspension Products
Old Oct 27, 2004 | 06:12 PM
prostreetonline's Avatar
Default Eibach Suspension Products
We carry the full line of Eibach suspension products. Click below to see all of our products. For the full line of Exedy products, click here:
SCROLL DOWN FOR MORE PRODUCTS
Old Oct 27, 2004 | 06:14 PM
Default Re: Eibach Suspension Products (prostreetonline)
Eibach Pro Kit Springs
The Eibach Pro-Kit dramatically improves both a vehicle's performance and appearance.
Every Eibach Pro-Kit is designed and tested by suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
CLICK HERE FOR PRICES AND APPLICATIONS
Old Oct 27, 2004 | 06:15 PM
Eibach Sportline Springs
Eibach has engineered their springs to lower your vehicles center of gravity. They also reduce rear squat during acceleration, body roll in coners and excessive nose-dive under braking while maintaining ride quality.
Eibach Sportline springs achieve legendary handling by aggressively lowering the vehicles center of gravity with precision engineered spring rates. Created for the hard-core street enthusiast who wants that race-car attitude with the lowest possible drop while maintaining ride quality
CLICK HERE FOR PRODUCTS AND APPLICATIONS
Old Oct 27, 2004 | 06:16 PM
Eibach Camber Alignment Kits
After the installation of either an Eibach Pro-Kit or Sportline spring set, a vehicle's alignment should always be checked. Once lowered, a wheel's camber may become increasingly negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in peculiar handling and accelerated tire wear.
Eibach offers a complete range of alignment kits which offer a simple, affordable solution to adjust negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications but they also allow the experienced chassis tuner to utilize the increased adjustment range to dial-in a performance alignment that uses negative camber to maximize a chassis' potential. Turn-in becomes more precise and handling increasingly crisp and predictable. High-speed stability is also enhanced making an alignment kit from Eibach almost a necessity for the serious performance tuner.
Old Nov 1, 2004 | 10:06 AM
Eibach Anti Roll Kits
Complete your suspension upgrade with an Eibach Anit-Roll-Kit. Eibach Anti-Roll-Kits further reduce body roll through increased design stiffness over stock bars. The result is increased handling and cornering grip in any performance-driving situation. Manufactured from cold-formed, high strength aircraft-grade steel for precision performance and finished with a long lasting powder coat finish. Anti-Roll-Kits come with all mounting hardware and instructions for easy installation.
Eibach Anti-Roll-Kits come in sets only with front and rear Anti-Roll-Bars unless otherwise noted
EIBACH ANTI ROLL SWAY BARS
BiGcAmBoDiAnSaUsAgE
Southeast (Sales)
Sep 3, 2008 04:16 PM
travail06
Honda Civic (2006 - 2015)
Jul 30, 2006 06:24 AM
prostreetonline
Dec 5, 2005 03:51 PM
prostreetonline
Sep 6, 2004 09:01 PM
