Engine wiring harness
Old Oct 27, 2004 | 05:32 PM
Seven Deuce's Avatar
Default Engine wiring harness
Can someone tell me if i can use my stock engine wiring harness and just connect it up to the 2nd gen b16a i have a d16z6 harness are they the same ?
Old Oct 27, 2004 | 05:35 PM
Luserkid's Avatar
Default Re: Engine wiring harness (Seven Deuce)
Sure.
Kyles ej1's Avatar
nope get an obdII - obdI harness
Old Oct 27, 2004 | 05:36 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seven Deuce &raquo;</TD></TR><TR><TD CLASS="quote">Can someone tell me if i can use my stock engine wiring harness and just connect it up to the 2nd gen b16a i have a d16z6 harness are they the same ?</TD></TR></TABLE>
everything should plug in except for the knock sensor. 92-95 civics never came with knock sensors (except b16 del sols).
Old Oct 27, 2004 | 05:37 PM
chad's Avatar
Moderator
Default Re: Engine wiring harness (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe &raquo;</TD></TR><TR><TD CLASS="quote">nope get an obdII - obdI harness</TD></TR></TABLE>
do you have a clue?? that is so much the wrong info!!!
Old Oct 27, 2004 | 05:38 PM
Luserkid's Avatar
1st Gen - 89-91
2nd Gen - 92 - 95 SIR Also in the Del Sol VTEC
3rd Gen - 99 - 00 SI
Isnt that right?
Old Oct 27, 2004 | 08:19 PM
hatchi's Avatar
yes plug n play and add knock sensor unless you want to run chipped ecu that eliminates knock
Old Oct 27, 2004 | 09:08 PM
92eh3si's Avatar
Default Re: Engine wiring harness (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">yes plug n play and add knock sensor unless you want to run chipped ecu that eliminates knock</TD></TR></TABLE>
i had to add a KS wire into my GSR in 92 HB.
personally i would wire it than runnin a chipped ecu.
up to u tho.
Old Oct 28, 2004 | 05:57 PM
thanks for all the info very helpfull
RB_EJ8
11
Aug 26, 2009 09:29 PM
ekdriven
Mar 10, 2005 06:16 PM
dpine
Feb 25, 2005 04:15 PM
Relick!
Oct 31, 2004 01:41 AM
txhatch
Aug 22, 2003 10:55 PM
