1991 Honda CRX SI Dark deminishing Oil.
Im hoping someone on this form can help me out with this?
I have a 1991 Honda CRX SI, Just had the engine Re-Built, Car runs perfectly except for one problem that just bugs.
The car at about 700 miles starts to Burn or Loose oil. There are no leaks underneith or where I park.
At about 1000 miles I have to either add more oil, Or change the oil.
When I change the oil at 1000 miles it comes out BLACK. TO BLACK!
Checked Compression 195,195,185,198. I've been told the 185 is not enough to worry about, and is normal on a honda motor.
I was also told it might be running rich, O2 Sensor reads fine, and no check engine.
I am at the point im think its running LEAN, But I really am not sure anymore.
Any help from anyone you be GREAT!?
HOOK ME UP! PLEASE!
HOOK ME UP! PLEASE!
you need to seat the rings...
it's common after a rebuild to have a little blow-by until the rings are seated properly. this "usually" takes anywhere from 500-1000 miles, though you should not be beating on your car for a while. let **** break in properly.
Actually found the problem to my own question... and It was something pretty easy, little expensive though, the catalytic converter has gone bad/Melted a little. This creates to much BACK pressure and creats a whole world of problems...
RyanF_2010
Jan 2, 2016 07:18 PM
ray_saul
Honda Civic (2006 - 2015)
18
Jun 30, 2013 07:46 AM
2001B18C1GS-R
22
Nov 7, 2011 08:14 AM
schueytenten
Jul 7, 2006 11:01 AM
Darwin022
22
Jul 28, 2004 05:30 AM
