O2 Sensor Problem
Old Oct 27, 2004 | 04:28 PM
JaymieTypeR's Avatar
Default O2 Sensor Problem
Ok i searched but could really find what i was lookin for.
if you wire up a O2 sensor incorrectly will it normally come on right away or will it take awhile.
i got a new O2 sensor in my car but still got the O2 code, only when i drive the car hard, which would lead me to belive something is wrong with the wiring possibly?
any help appreciated
thanks
Modified by JaymieTypeR at 10:56 PM 10/30/2004
Old Oct 27, 2004 | 06:32 PM
Default Re: O2 Sensor Problem (JaymieTypeR)
bump this forum moves fast
Old Oct 28, 2004 | 12:53 PM
any ideas where to start?
Old Oct 30, 2004 | 09:56 PM
bump
i need some help
Old Oct 31, 2004 | 03:52 AM
EK45VTi's Avatar
hmmmmmmmmmm... sounds to me like you have a bad sensor... and YES, new sensor can be faulty too...
Is it Honda OEM sensor or some aftermarket sensor?
Why would you rewire the sensor if you just replaced it? If you rewired it, did you isolate the wires properly? Does your wire touches something hot like engine block, exhaust pipe or manifold, anything????
Old Oct 31, 2004 | 03:17 PM
Default Re: O2 Sensor Problem (KKVTi)
yes its a honda oem sensor, and if they were touching anything why would that cause a cel?
i got the motor from a friend and i know he just put in a new O2 and it was running fine in his car, thats why i thought maybe the wiring was messed up. but it only comes on after hard driving and i let it come back down to a normal speed.
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
minituner
Mar 26, 2016 04:16 PM
grndslm
Jul 5, 2012 05:11 PM
PH3593A
Oct 13, 2004 10:14 AM
Green94GSR
Mar 1, 2004 02:05 PM
