Steering Assebly & Trunk Light ??
I apologize for not being to mechanically knowledgable...
I've got a 89 civic Sedan DX and my steering wheel is totally crooked, my uncle let his students mess with my car while he was replacing one of the front axels and so they screwed it up...
I would like to know how to straighten it...
My second problem, just started a day ago... My trunk light just magically decided to turn on 24/7 ... When I open the trunk, it turns off... But otherwise, while it's closed its always on and it's quite an annoyance...
How do I fix this? Where is the trigger for this light?
The trunk IS closing properly and IS secure, so I'm not sure.
Thanks!
Thanks!
well first of all they messed up your alignment because thats the only way besides actually unbolting the steering wheel and turning it and bolting it back in that they could have messed it up. actually its the toe that they messed up on the front end so if you go and get a front wheel alignment and tell them to make sure they put the steering straight because alot of ppl dont do that. so that solves that problem. and about your trunk light you might check the switch in the trunk that turns it of when it closes. its probably bad. well i hope that helps you later.
oh and dont attempt to fix the alignment yourself it would be so much easier to have it taken to a alignment shop where they can get the toe specs right and fix the steering.
The-Kid
Sep 3, 2008 04:34 AM
AndyD
Feb 2, 2003 05:14 PM
