ITR Rear Sway Bar Bushings
Hi, i was told that the oem Itr rear sway mounting bushings are polyurethane, its just that they are painted black. Does anybody know if this is true? Also, does anybody know if the oem endlink bbushings are polyurethane also? o one more quesiton, do ppl recommend the bsq or the beak's install kit?
the stock bushings are rubber not polyurethane.
the bsq/beaks kits are not required when mounting the ITR rear sway to a ITR.
if the bar is for a hatch I would get the beaks.
the oem bar bushing is quite nice....
the end link bushings need to be replaced every so often due to excessive wear.
Got Utensils
Suspension & Brakes
Oct 8, 2007 11:06 PM
