Header for B16 EF...
Old Dec 20, 2001 | 10:13 AM
FreeMyndz v.FP's Avatar
Default Header for B16 EF...
Who knows whether or not anything has to be modified for a DC 4-1 to fit on my motor...I have the hasport kit
Old Dec 20, 2001 | 10:23 AM
marty's Avatar
Default Re: Header for B16 EF... (FreeMyndz)
modify your cross member, or you can buy a Z10 chromaly front cross member that clears any one piece header. if you have the hasport mounts, you might have to actually cut into your cross member about 4 inches to clear the headers. check it out ! you have to remove your cross member to apply the headers so you should estimate about how much to bang or cut off to clear.
Old Dec 20, 2001 | 10:35 AM
Default Re: Header for B16 EF... (MugenEF7)
what's the site for Z10 engineering....
Old Dec 20, 2001 | 03:43 PM
Red Civic T's Avatar
New User
PlaceRacing also has a x-member that works....I have a b16a in 91 Civic EX with HASport mounts and had NO room without x-member adaption...
Old Dec 20, 2001 | 06:50 PM
Mr.FBR's Avatar
Default Re: Header for B16 EF... (Red Civic T)
The Q is are you going to spend $550 to make a header work when you can just notch it out or use the multi use hammer to make it work? I have seen kids w/ 4-1 dc's with hasport...it shouldn't be too difficult to work.
Old Dec 20, 2001 | 07:32 PM
BoostedED9's Avatar
Default Re: Header for B16 EF... (Mr.FBR)
what about a header for a 91 hatch with b16 and hcp kit??? wich header woudl fit without having to beat the x member???
Old Dec 20, 2001 | 08:15 PM
Blown90hatcH's Avatar
Default Re: Header for B16 EF... (ED9Hybrid)
If you have the HCP kit, get the header for a 99-00 Si from DC. It clears fine.
Old Dec 20, 2001 | 09:28 PM
AfEn808's Avatar
New User
Default Re: Header for B16 EF... (Blown90hatcH)
you think a type r header would fit into a crx with b16.
Old Dec 20, 2001 | 09:51 PM
big pete's Avatar
Default Re: Header for B16 EF... (AfEn808)
i have a hasport kit.......use a ls header
[Modified by big pete, 6:51 AM 12/21/2001]
Old Dec 20, 2001 | 09:54 PM
yep. It will be alittle bit lower, but only about 8mm.
[Modified by Blown90hatcH, 9:44 AM 12/21/2001]
Old Dec 20, 2001 | 09:55 PM
internet ay's Avatar
Default Re: Header for B16 EF... (big pete)
i had a dc 4into1 in my b16 crx had to beat the hell out of my crossmember to get it to fit and i bottomed that thing out every day.
Old Dec 21, 2001 | 03:32 AM
Mista Bone's Avatar
D Tranny Guru
I hope you are joking????
8 cm = 3 inches!
I hope you really meant 8 mm, about 3/8" of a inch.
Old Dec 21, 2001 | 06:04 AM
Phatwhippin_CRX's Avatar
Default Re: Header for B16 EF... (Mista Bone)
I've got a DC 4-1 on mine..... small notch into the CM.... not real hard...
Old Dec 21, 2001 | 08:43 AM
8 cm = 3 inches!
Oh yeah...hehe...8mm taller on the B18 vs. the B16a
Old Dec 21, 2001 | 03:27 PM
Hyper9's Avatar
Default place racing
makes a nice bolt on xmember also for under $300
Old Dec 21, 2001 | 05:18 PM
New User
Default Re: place racing (Hyper9)
where did you get figure of $500 for x-member? mine was 180...
true, could cut out x-member but at least on mine would have SUBSTANTIALLY weakened it by how much metal would have to be cut for header (DC 4:1)...
Old Dec 22, 2001 | 02:04 AM
kefka's Avatar
Default Re: place racing (Red Civic T)
the power gains on a 4-1 header are nice cut that shiot,its worth it, but if your gonna cut it then you better buy a header with at least a 2.5 collector,its no use buying a dc 4-1 header with goes into a stock piping sized collector.
tcgordy
Jan 13, 2007 05:38 AM
xDicktonesx
10
Jun 4, 2005 12:37 PM
xDicktonesx
May 14, 2005 01:54 PM
ecumatt
25
Oct 5, 2004 08:53 AM
Rydaddy
Oct 28, 2002 09:21 AM
