K20A2 immobilizer......help???
Old Oct 27, 2004 | 01:07 PM
6_GeArEd_TEG's Avatar
Default K20A2 immobilizer......help???
Ok. I know people that know how to remove the immobilizer don't wanna give it up for fear of people stealing rsx's, but damn some1 help me out. I was planning on takin my car to Acura and having them reflash the ecu and aget a key made and blah blah. Hasport said just send your ecu to locashracing.com and have it removed. I havn't checked but I think they said it was about $150. I've got the damn thing in and ready to go and I'm already almost sick of this swap. Ive ran into so much bs and crap I just wanna get the thing runnin. If no1 wants to pm me on how to remove the immobilizer then does any1 have a schematics/diagram of the k20a2 usdm rsx ecu?
Old Oct 27, 2004 | 02:16 PM
3minburnout's Avatar
Default Re: K20A2 immobilizer......help??? (6_GeArEd_TEG)
i know that this is not answering ur questing but i very interested in this swap for my teg and would be interested to know what bs and crap u have run into or just what problems ? if u could respond that would be great thanks in advance
Old Oct 27, 2004 | 04:14 PM
v4lu3s's Avatar
RTFM
i suspect that the people that do know how do it for a business...andyou dont make it as a business telling people how to do what you do for a living.
Old Oct 27, 2004 | 06:40 PM
hybrid racing's Avatar
Send me am email and i can help you out.
Old Oct 28, 2004 | 06:06 AM
boosted_dc2's Avatar
Default Re: (hybrid racing)
i was under the impression that it was just a chip in the ecu that needed to be removed.
Landon
Old Oct 28, 2004 | 10:29 AM
granteeton's Avatar
get a k-pro and have it eliminated.
Old Oct 28, 2004 | 01:02 PM
Default Re: (granteeton)
email replied. k-pro= $$$ that i don't have right now.
Old Oct 29, 2004 | 03:42 AM
Default Re: (6_GeArEd_TEG)
hybrid racing hasnt replied yet. Any1 else???? I would really like to get this thing running this weekend.
Old Oct 29, 2004 | 03:12 PM
diagrams?
Old Oct 29, 2004 | 09:30 PM
looks like i will have to send the damn thing to some1
Old Oct 29, 2004 | 11:43 PM
JDMotive's Avatar
I havent found a way to disable the type S immobilizer,but havent relly tried too hard.Ive used the type R ecu and K pro type S ecu's to bypass the immobilizer function.You can have the type S ecu reflashed from the dealership to remove the immobilizer,but if you do not have paperwork they may not do it.
Old Oct 30, 2004 | 12:19 AM
Default Re: K20A2 immobilizer......help??? (JDMotive)
Any1 know for sure if the dealership will be able to reflash it and let me use the integra key? Or will they have to cut a key and use the sending unit near the ignition too? I have the reciept of sale from the junkyard with vin numbers for this purpose, but if they have to cut a key and use the sending unit I'd get charged out the *** I'm sure. I was under the impression this is what they had to do. So I posted this looking for help.
Old Oct 30, 2004 | 08:42 AM
??????? 1 more bump after this and im done with it
Old Oct 30, 2004 | 02:00 PM
last bump
Old Oct 30, 2004 | 04:25 PM
JDMotive's Avatar
Integra's dont use immobilizer's...i havent messed with the 99-00 so they may have them..not sure.I know that the 94-98 dont.If the dealership reflashes the ecu to remove the immobilizer,the integra key will work without having to use any other part from the rsx.
Old Oct 30, 2004 | 07:44 PM
thanks man. I'll call the dealership and see if they can. I figured there would be some soldering off of wires or something though to completely disable the immobilizer?????
Old Oct 30, 2004 | 08:57 PM
JDMotive's Avatar
They can completely remove the immobilizer.Just talked to a guy that works at acura.No soldering or wiring.It's just a reflash done by a computer.
Old Oct 30, 2004 | 09:04 PM
YOU.... ARE...... THE..... MAN!
Old Nov 1, 2004 | 12:57 PM
called the dealership. they dont have a damn clue about it. said I'm better off sending it off. oh well screw it.
Old Nov 2, 2004 | 09:29 AM
JDMotive's Avatar
I can have it done for you if you need.Ive had it done before and its never been a problem.
Old Nov 2, 2004 | 10:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">I can have it done for you if you need.Ive had it done before and its never been a problem.</TD></TR></TABLE>
you just said that hondas dont have an imobilizer, but youve done it before
Landon
Old Nov 2, 2004 | 10:48 AM
6SPD_EK's Avatar
Default Re: K20A2 immobilizer......help??? (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE>
reading is essential - re-read his post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">Integra's dont use immobilizer's...i havent messed with the 99-00 so they may have them..not sure.I know that the 94-98 dont.If the dealership reflashes the ecu to remove the immobilizer,the integra key will work without having to use any other part from the rsx.</TD></TR></TABLE>
he clearly states he is speaking of 94-98 tegs...I had a 2000 teg GSR w/immobilizer.
as long as everything is legit (motor vin and/or paper work & ECU is legit) a dealership CAN remove the immobilizer function (from the RSX-S ECU) by means of a reflash...his local dealership probably doesn't know they can do this b/c this is a VERY UNCOMMON thing to ask when you bring your car in. I bet you if he called his dealership up - explained the case, the head tech could find out how to do it & do it for you....otherwise JDMotive is saying he can bring it to his local dealer to have it done
if you don't have a connection at the dealership I would be worried how much they would charge for this
Old Nov 2, 2004 | 10:58 AM
thats more of a flip flop statement than john kerry, ive never dealt with an imobilizer before, but i have had one removed before.
Landon
Old Nov 2, 2004 | 12:46 PM
JDMotive's Avatar
What I meant was I havent found a way to bypass the immobilizer in the Type S ecu as you can with the type R ecu.You can have it completely removed by the dealership though.
Ive never dealt with a 99-01 integra,so not too sure about their immobilizer's.
People should probably read more into the post's.
Old Nov 2, 2004 | 12:58 PM
well I called 2 places. It seems like they were lost from the beginning of the conversation. which kinda pissed me off cuz it wasn't that complex of a thing. Locash racing does it for 150 bucks, but they never answer their phone. I leave messages and they never return them. So I'm not gonna send it there cuz I need it back quick and I dont wanna deal with some1 that I can't talk to. I may try a few more dealerships in different city's. I'd like to send this thing somewhere though on Wed. Any 1 have any other places in mind?
