POS Ecu!!!
Old Oct 27, 2004 | 11:49 AM
jDmImagE's Avatar
Default POS Ecu!!!
Okay so i bought a JDM P08 Ecu from some shop on Ebay( I should have known better! ), it came with a skunk2 chip. When I start my car with this ecu it makes the cars idle jump up and down between 1500 and 2000 rpm's. I tried driving it and i drives like crap...does this mean that this computer is fried...Please Help!
Old Oct 27, 2004 | 11:50 AM
BauleyCivic's Avatar
Risky Business
Default Re: POS Ecu!!! (jDmImagE)
What engine is it running? Is the chip for the motor that you have in your car?
Old Oct 27, 2004 | 12:49 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: POS Ecu!!! (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">What engine is it running? Is the chip for the motor that you have in your car?</TD></TR></TABLE>
start there and also is it swapped? did you get the tps and map sensors installed correctly?
Old Oct 27, 2004 | 12:51 PM
NSTY Z33's Avatar
Does not mean it's "fried". Don't jump to conclusions. Some knolegeable people will help you around here.
Old Oct 27, 2004 | 05:46 PM
jDmImagE's Avatar
the skunk2 chip says its for a b16 motor, but i have a b18c1 now...well its a b18c1 block with a b16 head and b20 throttle body....i had a b16 in the car before but just put this motor in about a month ago, and yes all of the sensors are hooked up right...could it be that the ecu is automatic?
Old Oct 27, 2004 | 05:58 PM
jDmImagE's Avatar
Default Re: (jDmImagE)
Oh yeah i forgot to mention that the car runs fine with any other ecu.
Old Oct 27, 2004 | 06:08 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmImagE &raquo;</TD></TR><TR><TD CLASS="quote">Oh yeah i forgot to mention that the car runs fine with any other ecu.</TD></TR></TABLE>
an auto wont matter. my p28 is for an auto. it works fine, but if other ecu's work fine, then i would think you have an ecu issue.
Old Oct 27, 2004 | 08:17 PM
hatchi's Avatar
did you try changing the chip? maybe it wasnt socketed properly
Old Oct 27, 2004 | 08:26 PM
Patron's Avatar
no your ecu isn't fried. if it was fried it wouldn't even start, you'd have a CEL of 1, Solid CEL.
Tank INC.
Sep 24, 2007 11:01 AM
JolleyRanchaMan
Oct 13, 2006 11:44 AM
mEr
Jan 22, 2004 04:14 PM
Jx3069
Sep 1, 2003 08:02 AM
mugensport9
Apr 27, 2003 07:56 PM
