88 civic wont start when hot
Old Oct 27, 2004 | 11:47 AM
draw's Avatar
Default 88 civic wont start when hot
Hey i have a 88 civic wit the 1.5 and it wont start when its hot. First off its not all the time either some times it will start right up some times it wont. When it wont start if i leave it long enough it will start, or if im in a hurry i pull the negative and reset the comp and it will start. When it wont start if i crank long enough it will log a injector code. i changed the throtle body for a unrelated reason (it was from the wrecker so it had a diffrent set of injectors in it), and the car is still doing it. Also about 8 months ago i replaced the distributor b/c the car would just die and not start. So i was thinking it could be the distributor on its way out? Any ideas would be awsome.
Old Oct 27, 2004 | 11:50 AM
civickiller's Avatar
Default Re: 88 civic wont start when hot (draw)
main relay
Old Oct 27, 2004 | 12:22 PM
draw's Avatar
Default Re: 88 civic wont start when hot (civickiller)
yah ill try that
Old Oct 27, 2004 | 12:25 PM
notfastenough's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
Old Oct 27, 2004 | 01:09 PM
SL0WEGG's Avatar
Default Re: 88 civic wont start when hot (notfastenough)
igniter?
Old Oct 27, 2004 | 02:40 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
main relay..
See this site for trouble-shooting tips for a "no-start" situation:
http://autorepair.about.com/cs...a.htm
damithinkimlost
Jan 22, 2008 03:05 AM
Honda007
Jul 13, 2007 09:37 PM
slipperyduck
Dec 22, 2004 10:40 AM
