Need some Suggestions...I am having problems shifting gears!
Old Oct 27, 2004 | 11:45 AM
DarksolB16's Avatar
Default Need some Suggestions...I am having problems shifting gears!
Well I have a 93 si hatch with 91 ls swap and I used the Hasport Hydro-Cable conversion. For some reason when the car temperature is cold it shifts fine but when the car warms up I have severe problems switching gears......Any ideas on what this could be?
I dont know if its the tranny or clutch (ACT 6puck in it)or what.....Any info would be greatly appreciated.
Thanks
Old Oct 27, 2004 | 12:34 PM
dohcdelsol93's Avatar
Default Re: Need some Suggestions...I am having problems shifting gears! (DarksolB16)
change you mtf. I had the same problem with my 91 ls tranny and it cleaned it up.
Old Oct 27, 2004 | 07:36 PM
DarksolB16's Avatar
Default Re: Need some Suggestions...I am having problems shifting gears! (dohcdelsol93)
ok thx i will try that tomorrow and let you know if it helps
Old Oct 27, 2004 | 07:40 PM
hondainspired's Avatar
syncromesh is highly recommended... (i can vouch)
Old Oct 27, 2004 | 07:45 PM
DarksolB16's Avatar
Default Re: Need some Suggestions...I am having problems shifting gears! (hondainspired)
i have thought about that too......should i do that at the same time as changing the MTF?
Old Oct 27, 2004 | 08:05 PM
cappa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">syncromesh is highly recommended... (i can vouch)</TD></TR></TABLE>
Thats the GM **** right?
Old Oct 27, 2004 | 08:15 PM
DarksolB16's Avatar
Default Re: Need some Suggestions...I am having problems shifting gears! (cappa)
yeah GM sychromesh
Old Oct 27, 2004 | 09:06 PM
cappa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarksolB16 &raquo;</TD></TR><TR><TD CLASS="quote">yeah GM sychromesh
Thanks Man
baked_beanz
Jul 22, 2005 10:13 AM
ricearoni56
Dec 2, 2004 04:44 PM
05 S2K Stoner
Nov 20, 2004 06:29 PM
methred_92
May 22, 2002 09:20 PM
