Sensors and Race Gas?
Old Oct 27, 2004 | 06:25 AM
GumballNA's Avatar
Default Sensors and Race Gas?
I was curious to know if Race gas, burns out o2 sensors? And if so how would you run the car if you had high compression, and need 100-110 race gas?
Old Oct 27, 2004 | 06:38 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Sensors and Race Gas? (GumballNA)
I have seen race gas kill 02 sensors before, but not all of them. I am not sure what makes it burn some, but not others . . . anyone else know?
Old Oct 27, 2004 | 06:58 AM
GumballNA's Avatar
Default Re: Sensors and Race Gas? (HybridHatch88)
is there a way to run a chipped ecu, without an o2 sensor then?
Old Oct 27, 2004 | 07:04 AM
Phil Koury's Avatar
Only thing i've seen is cars chewing through spark plugs while on c16, a few pulls on the dyno and it was time for another set...never really have seen it happen to an o2 sensor but i guess its possible.
Old Oct 27, 2004 | 07:13 AM
sloanrad's Avatar
Default Re: Sensors and Race Gas? (pkoury)
Leaded race gas will shorten the life of O2 sensors. I've ran a fjo wide band for 2 seasons with no problem. Aem wide band also all this year and there replacement o2 is very reasonable. Also AEM will warrenty them for 1 year.
Old Oct 27, 2004 | 07:39 AM
bluebird's Avatar
Default Re: Sensors and Race Gas? (sloanrad)
burned our o2 this weekend at pomona!!
Old Oct 27, 2004 | 09:16 AM
Kataku2K3's Avatar
Default Re: Sensors and Race Gas? (bluebird)
Leaded gases are said to shorten the life of an O2 to ~1/100th of the original.
Old Oct 27, 2004 | 01:26 PM
GumballNA's Avatar
Default Re: Sensors and Race Gas? (Kataku2K3)
is 110 usually leaded? Im not sure, because I haven't looked into any race gas locally yet.
Old Oct 27, 2004 | 01:59 PM
revolt_allmotor's Avatar
Yes the majority of race gas is leaded. Check out http://www.vpracingfuels.com/i...620F6
for info about a lot of common race gas. I've personally used I think 8 different kinds of leaded VP and never run any of their unleaded stuff. I've heard the Motorsport 103 makes good power though. Get ready to pay $10+/gallon for anything other than the typical shelf-stock stuff though.
Old Oct 27, 2004 | 06:50 PM
sleeping GIANT's Avatar
Default Re: Sensors and Race Gas? (909edge)
yes it will chew a spark plug up! yes it will shorten the life of the 02 sensor. but I have started running m1o by vp and its unleaded. $5.25 / gallon
Old Oct 27, 2004 | 07:48 PM
GumballNA's Avatar
Default Re: Sensors and Race Gas? (sleeping GIANT)
where are the prices on that site? or do you have to contact?
Old Oct 27, 2004 | 10:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeping GIANT &raquo;</TD></TR><TR><TD CLASS="quote"> I have started running m1o by vp and its unleaded. $5.25 / gallon </TD></TR></TABLE>
m1o = motorsport 100e?
Old Oct 27, 2004 | 11:52 PM
tony1's Avatar
Life expectancy of wide band sensors on leaded fuel is only around 50 hours...
1320king
Engine Management and Tuning
Jan 3, 2014 10:19 PM
CustomX113
Mar 5, 2007 10:43 PM
b18c195
Dec 13, 2005 07:27 AM
Rod.
Sep 6, 2004 02:23 PM
STrEet11SeCTurBoEG
May 10, 2004 04:36 PM
