Fuel Rail Connection ... Need Help.
Old Dec 20, 2001 | 07:45 AM
AdamITR's Avatar
Default Fuel Rail Connection ... Need Help.
I am using a AEM fuel filter on my R with 6-AN braided fuel line. I need to connect the fuel line to the stock fuel rail inlet. Does anyone know how I go about doing this? The fuel line has a 6-AN female straight/swivel earls fitting on it. The stock fuel rail has a male inlet ... I think it accepts a 4-AN fitting? Perhaps the thread is 12mmx1.5 or 1.25? Thanks
Old Dec 20, 2001 | 07:51 AM
MackSpeed-616's Avatar
Default Re: Fuel Rail Connection ... Need Help. (AdamITR)
why dont you just get an aem, or other aftermarket fuel rail?
Old Dec 20, 2001 | 07:52 AM
AdamITR's Avatar
Default Re: Fuel Rail Connection ... Need Help. (TurboR616)
I have an AEM fuel rail already. HOWEVER, the AEM rail in Not allowed in the Honda-Challenge Race series, so I have to go back to stock.
Old Dec 20, 2001 | 08:54 AM
sgT's Avatar
sgT
Isnt the AEM fuel filter supposed to be bolt in?
It should have come with the hardware for the banjo fitting.
And no, the rail doesnt have a -4 end. its a banjo fitting.
Old Dec 20, 2001 | 08:55 AM
Default Re: Fuel Rail Connection ... Need Help. (sgT)
DAYM!!! CURRIED y0!
Old Dec 20, 2001 | 09:06 AM
Mike M's Avatar
Founding Member
Is this in Stock class or Fully Modded class? Damn I better go read through the rule book again
Old Dec 20, 2001 | 09:11 AM
AdamITR's Avatar
Yes, the AEM fuel filter is a basic bolt-in unit. Yes, the stock fuel line w/banjo fittings will work. However, I want to use my S.S. braided line though.
Here's a pic of my current set-up.
Old Dec 20, 2001 | 09:12 AM
AdamITR's Avatar
Default Re: Fuel Rail Connection ... Need Help. (TypeRmsm)
This is for the stock H2 class ... it's allowed in H1.
http://www.bseries.net/forums/showth...&threadid=1515
[Modified by AdamITR, 1:15 PM 12/20/2001]
Old Dec 20, 2001 | 09:27 AM
DB2-R81's Avatar
25 Year Member
I am in the same situation as you with a different sanctioning body, change the rail and be forced to change competition class.
Unscrew the male fitting from the rail, if you want a -6, 45-degree forged fitting order a part number 1267 from Goodridge. If you want a 90-degree order 1279 and if you want a straight T with a fuel pressure fitting order a 1291. The fuel rail thread is M12 X 1.25. These fitting were originally designed for Dellorto carburetors and are special order from Europe. I have tried all the fitting manufactures in North America and no one has the correct metric fitting except Goodridge. Talk to George Lugo at Goodridge, Ca. customer service supervisor 310 522-1924 and tell him we want these in North America. Your only other option is to re tap the rail to standard size and use the appropriate fitting.
[Modified by DB1-R81, 1:01 PM 12/20/2001]
Old Dec 20, 2001 | 09:32 AM
Cre's Avatar
Cre
Default Re: Fuel Rail Connection ... Need Help. (DB1-R81)
where can you order that fitting from ?
Old Dec 20, 2001 | 09:33 AM
DB2-R81's Avatar
25 Year Member
Default Re: Fuel Rail Connection ... Need Help. (Cre)
Check my post I edited it to let you know!
Old Dec 20, 2001 | 10:29 AM
AdamITR's Avatar
DB1-R81
Old Dec 20, 2001 | 11:32 AM
Striker's Avatar
New User
How'd you get your engine bay so clean?
Old Dec 20, 2001 | 11:39 AM
AdamITR's Avatar
Default Re: Fuel Rail Connection ... Need Help. (Striker)
It's a really old photo ... car was clean back in the day.
Adam who wishes his engine bay was still that clean!
Old Dec 20, 2001 | 12:18 PM
sgT's Avatar
sgT
Take your fuel rail off and have the banjo fitting cut off and then drilled and tapped
for a -6 fitting.
Old Dec 20, 2001 | 08:55 PM
Mista Bone's Avatar
D Tranny Guru
Pegasus Auto Racing
6AN to 12mmx1.25 carb adapter
#3275-12 $5.49
RACEPAK
Dec 5, 2006 12:38 AM
Mr. Anderson
Feb 21, 2005 08:01 AM
Que_Lude
Feb 2, 2003 10:07 PM
turboex
Jan 3, 2003 11:58 AM
