Need help getting Civic running
Old Oct 27, 2004 | 03:31 AM
jason418436's Avatar
Default Need help getting Civic running
I'm having a couple problems with my 95 Civic Ex. The first just happened this morning going to work. When I left my house my car was stalling a little bit when I would give it gas, so when I went to make a sharp turn i downshifted to second and took off, once I started going, my car acted like I downshifted again and jumped forward. I checked to see if it was in gear and once I saw it was, it died. Now when I go to start it, it turns over but it won't get fire. About 2 weeks ago my check engine light would come on every now and then, but I was assuming it was my o2 sensor because of the poor gas mileage I was getting and how extremely rich it was running. I was thinking maybe the o2 sensor went bad and the car isn't getting enough fuel to start, but I don't want to buy the sensor if that is the problem. Any ideas?
Also, I replaced my clutch not too long ago, because it sounded like my throw-out bearing was going bad. I replaced the clutch and the car still makes the same noise. When I press in on the clutch it stops, but at an idle in neutral without the clutch pressed in, it makes a noise similar to a throw-out bearing going out. Once again, any ideas?
Thanks for your time and reading this, it's greatly appreciated!
-Jason
Old Oct 27, 2004 | 05:02 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Need help getting Civic running (jason418436)
your clutch noise is probably your input shaft bearing. as for the no spark, it could be a dizzy, or a main relay.
Old Oct 27, 2004 | 05:53 AM
spoonek9's Avatar
Default Re: Need help getting Civic running (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">your clutch noise is probably your input shaft bearing. as for the no spark, it could be a dizzy, or a main relay.</TD></TR></TABLE>
I agree on both
Old Oct 28, 2004 | 09:55 PM
It was my timing belt, thankfully no damage to the head. How hard would the input shaft bearing be to fix? How much would the labor be on fixing it if I took it somewhere? Also, could it possibly be the pilot bearing?
turbofreak521
12
Aug 24, 2011 01:48 PM
omniscient
Sep 28, 2007 06:36 PM
175Shot4Door
Sep 20, 2006 08:17 AM
NitroStickers
Nov 19, 2005 11:04 AM
tuan...
13
Feb 24, 2005 09:06 PM
