Will a d16z6 fit in a.......
Old Oct 26, 2004 | 10:14 PM
98HondaCivEX's Avatar
Default Will a d16z6 fit in a.......
EJ8 aka 98 Honda Civic Coupe will this drop in in place of my d16y8
Old Oct 26, 2004 | 10:18 PM
Echelon's Avatar
Default Re: Will a d16z6 fit in a....... (98HondaCivEX)
It's basically the same motor, except you will have to deal with OBD2 going to OBD1. I think the block is pretty much the same, the difference is in the head and the intake manifold.
Old Oct 26, 2004 | 10:21 PM
so all i would have to do is convert the obd2 to odb1 and nothing else so other than that it will drop RIGHT in
Old Oct 26, 2004 | 10:22 PM
Echelon's Avatar
Default Re: (98HondaCivEX)
Besides being OBD1 and OBD2 yes, it is a direct drop it. It will work with your current transmission as well.
Old Oct 26, 2004 | 10:28 PM
2000EM1's Avatar
Default Re: (Echelon)
I swear doing that swap is illegal, besides... WHY?
The y8 already makes 2 hp/1 ft lb over the z6.
Old Oct 26, 2004 | 10:29 PM
blaster834's Avatar
^ hah good point but ya why are you doing that anyways?
Old Oct 26, 2004 | 10:30 PM
Echelon's Avatar
Default Re: (revolution8k)
I think the z6 runs a bit lower compression than the y8. More ideal for turbocharging.
Old Oct 26, 2004 | 10:37 PM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echelon &raquo;</TD></TR><TR><TD CLASS="quote">I think the z6 runs a bit lower compression than the y8. More ideal for turbocharging.</TD></TR></TABLE>
Yeah, that .4:1 really makes all the difference in the world....
Old Oct 26, 2004 | 10:44 PM
Echelon's Avatar
Better than nothing. Plus z6's are more common and less expensive.
Old Oct 26, 2004 | 10:50 PM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echelon &raquo;</TD></TR><TR><TD CLASS="quote">Better than nothing. Plus z6's are more common and less expensive.</TD></TR></TABLE>
He should already have the y8... unless he blew it up.
However, I'm still fairly sure an obd2 --&gt; obd1 swap is illegal.
Old Oct 26, 2004 | 10:54 PM
Echelon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revolution8k &raquo;</TD></TR><TR><TD CLASS="quote">He should already have the y8... unless he blew it up.
However, I'm still fairly sure an obd2 --&gt; obd1 swap is illegal.</TD></TR></TABLE>
It is illegal. Putting a older motor into a newer chasis is illegal.
Old Oct 26, 2004 | 11:03 PM
yes... i have the y8 i dont ******* know what i wanna do god dannigt i wanna go fast thats what i wanna do
Old Oct 26, 2004 | 11:30 PM
jdmsiR20's Avatar
It is illegal. Putting a older motor into a newer chasis is illegal.</TD></TR></TABLE>
yeah it is, but to my understanding only in california?
but anyway, if it did blow up or something, source out a y8 for the mere fact that its younger. go to a wrecking yard, find an ex, and you're good. money spent now will be better in the long run.
and if you think you'll be saving money with the z6, the few hundred thats cheaper will have to be used to pay for the obdII&gt;obdI conversion.
good luck!
Old Oct 26, 2004 | 11:57 PM
SECURITY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98HondaCivEX &raquo;</TD></TR><TR><TD CLASS="quote">yes... i have the y8 i dont ******* know what i wanna do god dannigt i wanna go fast thats what i wanna do</TD></TR></TABLE>
You should stop making threads like this one and start using the search fuction.
PS D16Z6 are cheap cheap cheap because it isn't that easy to find one with under 100k miles anymore
Old Oct 27, 2004 | 12:05 AM
you should search and find my foot up your *** for being stupid if i wanted to search i would have
Old Oct 27, 2004 | 12:07 AM
and before your reply i really dont care what you think no one will have this exact same question with the exact same variables and everything so if i wanna ask a god dang question i will post it if i think its been covered ill search i didnt search for a reason so keep your smartass "search" comment to yourself
jerbear!'s Avatar
you dont know what to do and the only thing you came up with is swapping a older motor in? wow just turbo your y8.
Old Oct 27, 2004 | 12:11 AM
yeah the reason i want another motor is because i dont wanna build my motor WHILE its in the car so i was gonna buy a block and build it and then drop it in when m done... im fine with my stock motor for now
Old Oct 27, 2004 | 12:12 AM
i wanted to build on a block before i dropped it in and i dont have constant flow of cash so it would be build here and there so ill probably buy a new d16y8 and build it up and everything and drop it in a year or so
Old Oct 27, 2004 | 08:16 AM
2000EM1's Avatar
Then buy a turbo kit, or a Corvette.
Old Oct 27, 2004 | 08:19 AM
nighttrain33's Avatar
Default Re: (jdmsiR20)
It is illegal in California for sure, and maybe in some other states. It just depends on that state's emissions laws.
-Shane
Old Oct 27, 2004 | 08:23 AM
t0p_sh0tta's Avatar
Default Re: (nighttrain33)
In Connecticut changing a motor from OBD2 -&gt; OBD1 will automatically cause it to fail emissions. I am not sure as to the legality of swapping an older motor into a newer chasis though. I have a feeling that it is illegal.
Old Oct 27, 2004 | 08:46 AM
jdm123's Avatar
Default Re: (t0p_sh0tta)
Not trying to rain on your parade or anything but those are pretty much the exact same motors. Except for the fact that the z6 head flows better.
Old Oct 27, 2004 | 08:48 AM
v4lu3s's Avatar
RTFM
the best way to drop a z6 into a newer civic EX.
i woudl use the LONGBLOCK ONLY!
i would swap teh y8 manifold, sensors and injectors over, the distributor, and the thermostat housing and water tube. then you would need to swap over the cast metal mount that is bolted to teh block behind the timing cover from the obd2 engine to the obd1 engine.
doing all that will keep it obd2, make it run and keep it easy. i just did several of those swaps in teh past month.
Old Oct 27, 2004 | 08:51 AM
jdmsiR20's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98HondaCivEX &raquo;</TD></TR><TR><TD CLASS="quote">i wanted to build on a block before i dropped it in and i dont have constant flow of cash so it would be build here and there so ill probably buy a new d16y8 and build it up and everything and drop it in a year or so</TD></TR></TABLE>
so you can build a block but cant swap a motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98HondaCivEX &raquo;</TD></TR><TR><TD CLASS="quote">EJ8 aka 98 Honda Civic Coupe will this drop in in place of my d16y8 </TD></TR></TABLE>
quit being an ******* and people will help. my two cents were already in.
