How to make a ZC turbo friendly???
Old Dec 20, 2001 | 06:51 AM
REDBARON's Avatar
Default How to make a ZC turbo friendly???
Hey guys. Well I'm heard mixed reviews on this. I've heard that a ZC will blow up if turbo'ed and also that it's safe to turbo a ZC. So What is everyone's experience on this? And also how can you make the ZC turbo friendly??
Thanks for the help guys.
Old Dec 20, 2001 | 07:05 AM
CWBETB's Avatar
Default Re: How to make a ZC turbo friendly??? (VTECHatch)
Im running a turbo on my ZC at 5.5 pounds, with nothing done to the engine, only the FPR they supply you with, high octane gas, retarded the timing and colder plugs. I have been running this since the Early Fall without a problem
Old Dec 20, 2001 | 08:30 AM
swtcivic93's Avatar
New User
Default Re: How to make a ZC turbo friendly??? (CWBETB)
how does your car run?? cause i'm in the process right now of deciding what motor i want in my 89 hatch. some many options.
Old Dec 20, 2001 | 08:32 AM
Davep's Avatar
Yeah, any enigne that you turbocharge will blow up if you don't know what your doing. I boosted a zc with 7-10psi for 2+ years without any trouble at all. Do some research about what your going to do and you will be fine.
Old Dec 20, 2001 | 09:15 AM
CWBETB's Avatar
Default Re: How to make a ZC turbo friendly??? (Davep)
DaveP Since you had a turbo ZC, do you think I will run to any problems with my setup? I have been told I will be fine as long as I dont up the boost.
The car moves pretty good, Im sure high 14's in the 1/4mile. 1st gear is insane with the si trans, the tires slid all over, 2nd pulls hard, 3rd still got some juice but 4th is pretty flat.
Old Dec 20, 2001 | 10:49 AM
REDBARON's Avatar
Would I need to lower my CR?? Or should I just run one but at low boost?
Old Dec 20, 2001 | 01:04 PM
MNCRXSi's Avatar
My dad's 90 Civic SiZC is running about 8-10 lbs of boost, non intercooled for the summer months (ran it all this summer) no problems at all. Just know what your doing and you'll be fine. Make sure if your running over 5 you get a different fuel pump and make sure you have a FPR or FMU to make sure your getin fuel in there when boost kicks in. and again, do reasearch and you'll figure it out.
Old Dec 23, 2001 | 12:46 AM
KS-R's Avatar
You should be low 14s and high 13s... I ran low 14s with my turbo D16a6.. So you should be able to get lower ETs.
BooSTiN5thGeN
Dec 8, 2003 01:07 PM
OutLuDeD
Apr 17, 2003 10:31 AM
ZCcivic91
Aug 13, 2002 09:33 AM
REDBARON
11
Dec 13, 2001 06:15 AM
