Wiring Help on a 94 GSR in a 88 CRX
Old Oct 26, 2004 | 09:38 PM
BraydenR's Avatar
Default Wiring Help on a 94 GSR in a 88 CRX
I am looking for the wiring diagram for a 94 Gsr and how to hook it up to a 88 CRX need to re wire my GSR in my CRX and too see what i am missing or isnt hooked up any help would be great thanks
Old Oct 26, 2004 | 09:48 PM
Nerologic's Avatar
what ecu r u running? are u staying obd0 or converting to obd1??
Old Oct 26, 2004 | 10:04 PM
BraydenR's Avatar
Default Re: (Nerologic)
i am staying odo
add me to msn
krookedatmosphere@msn.com
Old Oct 26, 2004 | 10:20 PM
Rywire's Avatar
Default Re: (BraydenR)
if ur gunna stay obd0, wire it like a b16a.
Ryan
Old Oct 27, 2004 | 05:38 AM
barry11j's Avatar
Default Re: (droppedcrxsi)
you will have to run the knock sensor, v-tec sen and v-tec oil pressure pinS into the ECU
Old Oct 27, 2004 | 07:34 AM
Rywire's Avatar
Default Re: (barry11j)
The iab dosent work, so either take out the butterflys, or use a skunk2 mani. You are going to use a pr3/pwo, right?
Ryan
Old Oct 27, 2004 | 07:59 AM
BraydenR's Avatar
can anyone get me the wiring diagram
Old Oct 27, 2004 | 08:32 AM
deftones0817's Avatar
you dont need a wiring diagram. Contact blown90hatch and buy a obd0-obd1 conversion harness. Then everything pretty much plugs right in with your crx harness. This is what i did i just got done my b18c1 into 1989 crx hf like a week ago. Other than tohe o2 problem throwing a code my car runs great. (think im at fault with not a good connectiont to o2 sensor will check on friday)
DEF
Old Oct 27, 2004 | 09:24 AM
Rywire's Avatar
Default Re: (deftones0817)
he wants to stay obd0, but ya... he should go obd1 for sure.
Ryan
slocrx2
Dec 17, 2005 10:27 PM
BraydenR
Nov 30, 2004 09:14 AM
BraydenR
Oct 26, 2004 10:47 PM
turbotime.
May 1, 2003 12:42 AM
