Mount Recommendations
Old Oct 26, 2004 | 09:19 PM
Ricey McRicerton's Avatar
Default Mount Recommendations
It's time for new motor mounts. I want something that's not going to rattle me to death, but I need it to be able to hold my turbo Y7 still.
I'm thinking I may go with poly inserts, but I want some recommendations.
Old Oct 26, 2004 | 09:33 PM
boosted2point2ek's Avatar
Default Re: Mount Recommendations (Ricey McRicerton)
a couple of my friends are running enjo mounts they arent as bad on shaking as hasports and hold a built b20 spraying 125 pretty well
Old Oct 26, 2004 | 09:35 PM
dantastic's Avatar
i have ES mounts in the front torques and the rear tranny. it has a pretty healthy vibration at idle. it was worse when i had just the torques in.
Old Oct 28, 2004 | 02:07 PM
Default Re: (dantastic)
So, anybody else? Were the Es just inserts or full mounts? Where did you find them and for how much?
Old Oct 28, 2004 | 02:17 PM
alleyezonme's Avatar
Default Re: (Ricey McRicerton)
I have a friend that went to penn-tech, so he knows a lot of good car knowledge (even though he dropped out!). he told me how much more effieciently engines put down power all due to the poly inserts. I thought that was bs, but aren't race cars engines bolted directly to the frame?? i heard that one time too.
anyway that is the stuff i heard about poly inserts, but from my experience with it it does make a lot more vibration, but it is a good vibration. like the rumble of a V-8, ya know - good vibrating. i have hasport mounts on my civic w/ an h22 and i like it a lot more than stock mounts, so my vote says hasport mounts, or just get the poly inserts!
Old Oct 28, 2004 | 02:22 PM
Default Re: (alleyezonme)
^ i mentioned the race cars engines bolted to the frame b/c the less movement from the motor the better. so the stiffer the mount the better. I guess the motor is waisting energy rocking around with softer mounts, and with stiffer mounts the energy is forced to stay still. this is hard to explain but picture a drill wobling around like crazy. it is just a lot harder to drill something in b/c the drill is going nuts. but if you man up and hold the drill steady it works like butter. get it??
Old Oct 28, 2004 | 02:28 PM
b18bcivic's Avatar
I have poly inserts,a prothane race mount(driver's side)and a jdmshit mount for the tranny.My car vibrates alot,i wouldn't reccomend it for a street car.
Just get the inserts.
Old Oct 28, 2004 | 08:01 PM
thisisntjared's Avatar
bump. im looking for an answer too.
Old Oct 28, 2004 | 08:08 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Mount Recommendations (bleh)
ES rear insert is all you need to stiffen the engine a tad and not be too stiff. I have ES front torques and rear inserts. Very rattly and kind of annoying to most people- not to me obviously. I noticed a nice difference in throttle response and shifting
Old Oct 28, 2004 | 08:10 PM
eK9aT10pSi's Avatar
Default Re: Mount Recommendations (Emerika)
just go with energy suspension motor mount inserts, works well and stiffens it up just nice!
Old Oct 28, 2004 | 08:24 PM
blackdelslo's Avatar
Default Re: Mount Recommendations (eK9aT10pSi)
Ive also have the enjo mounts, they have a great 0 hassle customer service
Old Oct 28, 2004 | 08:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I want something that's not going to rattle me to death, but I need it to be able to hold my turbo Y7 still.
I'm thinking I may go with poly inserts, but I want some recommendations.</TD></TR></TABLE>from what ive read a few people say that the energy suspension inserts are too soft and a few complained that it does rattle. so my guess is that its stiff enough and not crazy. im poor and $36 shipped is nice:
https://honda-tech.com/zerothread?id=713941
Old Oct 28, 2004 | 08:34 PM
So those inserts just slide in with the original material in the mounts?
Old Oct 28, 2004 | 09:34 PM
from what ive read, yea
Old Oct 28, 2004 | 09:51 PM
Kengs's Avatar
I like my Spoon mounts; harder rubber than OEM but don't make my teeth rattle
Old Oct 29, 2004 | 10:51 AM
Default Re: Mount Recommendations (kengs)
Went and picked up the ES mount inserts today and I LOVE them. I haven't put in the rear one (did the 2 lower torque mounts first and didn't feel like fighting with the rear mount bolt). With just the torque mounts in, there is a noticed increase of rattling at idle, but it's nothing I can't life with, and there seem to be virtually no motor movement between shifts or under acceleration.
Best 45 dollars I've spend in a long time (I know I could have gotten them cheaper on here, but my local shop had them on hand).
Old Oct 29, 2004 | 10:52 AM
BauleyCivic's Avatar
Risky Business
Rear mount insert is the most noticable. Your shifts will be perfect.
acmoc
Mar 29, 2017 05:36 PM
Kaspk
17
Jan 19, 2008 06:54 PM
george34
21
Jan 22, 2006 07:30 PM
ykracing
Dec 13, 2002 05:20 AM
ragejed
May 18, 2002 06:56 PM
