help passing emissions?
Old Oct 26, 2004 | 08:50 PM
oneforce's Avatar
Default help passing emissions?
i have a 90 crx si, i have a single cam zc swap. how can i pass smog with it in california? im running a 89 integra ecu. some people say i can pass running the stock pm6 ecu. is that true?? thanks
Old Oct 26, 2004 | 08:56 PM
Rywire's Avatar
Default Re: help passing emissions? (oneforce)
Define smog? Ref, test only, regular emission smog check? Run a 90 pm6, and you should be fine.
Old Oct 26, 2004 | 09:01 PM
oneforce's Avatar
Default Re: help passing emissions? (droppedcrxsi)
i gotta go test only? anything special i have to do?
Old Oct 26, 2004 | 10:32 PM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneforce &raquo;</TD></TR><TR><TD CLASS="quote">i gotta go test only? anything special i have to do?</TD></TR></TABLE>
u need to pay some one 150 bucks to smog it if ur in ca , or else u need to swap in a stock sohc, ur car will NEVER pass a visual test with that motor
Old Oct 27, 2004 | 05:12 AM
92integra_gs's Avatar
yea wat Nerologic said...
as for anything special a nice tune up, oil change and filter ..duh!!! and new air filter would do the trick... btw get stock intake if you dont want to pay.. just maybe you get a damn *** smog ref... who dont know **** about hondas...lmao
Old Oct 27, 2004 | 05:51 AM
crx_88_si's Avatar
actually, can't those motors be used and noted as a Japanese replacement motor since they are virtually identicle.
Old Oct 27, 2004 | 07:32 AM
Rywire's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">actually, can't those motors be used and noted as a Japanese replacement motor since they are virtually identicle.</TD></TR></TABLE>
YA... the most you will have to do is use us parts on it such as ecu, and intake mani(not sure if the intake manis are identical or not) Engine has to be as old or newer than the car too.
Ryan
Old Oct 28, 2004 | 05:25 PM
951dc5's Avatar
Yeah dude...sy you better smog that piece of junk. I guess you already got more info here, but i think u should run your pm6, good luck bro! Or trash it like your del sor..haha
Old Oct 28, 2004 | 06:28 PM
kaoss_11's Avatar
B A N N E D
if u need a smog pm me
bpowa
16
Apr 21, 2005 12:08 AM
oneforce
Oct 27, 2004 09:15 PM
b-powa
Mar 13, 2004 07:10 PM
MikeyDB7
Apr 18, 2003 06:30 AM
